Hello Guest it is November 12, 2026, 08:01:26 PM
Author Topic: How to invert toolpath to match toolpath in CAM for Mach3 Turn  (Read 9678 times)
« on: November 10, 2015, 02:55:05 PM »
Hi all, my second topic, I have question , how to change toolpath in Mach3 Turn to match toolpath from CAM software, I have Emco Turn 220P with rear turret, I was surfing on net and
can not find topic (I found questions but no one answered to question), I believe it is possible to make just need information how?
Thank you in advance  :)
Re: How to invert toolpath to match toolpath in CAM for Mach3 Turn
« Reply #1 on: November 10, 2015, 08:16:38 PM »
There is a setting For Mach3 turn to use a REAR toolpost. This will do what you want.  Check the manual.
« Reply #2 on: November 11, 2015, 01:03:20 PM »
All I could find is tool table in manual by searching rear tool post so I was thinking that I need to change definition of tool (I am still cutting air so do not have tools), anyway I found one topic accidentally , on some old forum and solution is to check only one box, I thought it must be something easy , just did not know where to look any more. Any way thanks, I appreciate when somebody try to help. I already got new question what I need to ask, how to rotate tool path, I figured out how to zoom it and move it around, I before 2 years manage even to rotate it (because I had some old version of Mach 3) and today while I was reading manual, I read you can rotate tool path and I can not succeed to do it, and I was watching picture of machine piece that is rotated, so I was thinking I need to open new topic because I can not to do rotation.
Anyway I read again on some old forum that in newest version of Mach3 that is not possible, I guess it is true :)  ?
And yes here is how you invert tool path:
https://www.youtube.com/watch?v=e_9HAffmyao
