Hello Guest it is November 08, 2026, 12:30:47 PM
Author Topic: All configuration settings lost  (Read 8162 times)
« on: November 10, 2015, 01:44:47 PM »
Purchased an old Larken CNC in May, running Mach3 on XP.
When I booted up the computer today, all Mach 3 configuration settings were gone.  All input and output signals disabled, pins and ports set to 0.  Smooth stepper IP set to 0-0-0-0.  Home and soft limits disabled and set to 100/-100. Any way to recover the lost settings?  Would a system restore do it?
Re: All configuration settings lost
« Reply #1 on: November 10, 2015, 07:24:18 PM »
Copy one oif your .xml files from the xmlbackups folder into the Mach3 folder. You'll need to rename the extension.
