Hello Guest it is November 08, 2026, 01:28:26 AM
Author Topic: Mach3 + Geckos 201 + C11  (Read 13255 times)
SiN
« on: May 06, 2007, 10:25:36 PM »
Hi there,
Im trying to build a cnc router, mechanics are almost done, but electronics are the weak part of the project because of my complete lack of experience.
First of all im trying to control a single axis (X axis), power supply delivers 72v, the stepper wiring diagram as follows:
RED/-WHT = phase 1
YEL/-GRN =  phase 2
Communication with Arturo´s c11 is smooth, charge pump is fine, but when I send DIR and STEP signals, output leds flashes but theres no movement at all.
Any ideas?
Thanks in advance.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Mach3 + Geckos 201 + C11
« Reply #1 on: May 07, 2007, 12:25:23 AM »
Hi, SiN
Dose your stepper motor lock up with power on.
There should be low ohms reading from RED to WHT = phase 1 & connected to Gecko Phase A, B and YEL to GRN =  phase 2 to Gecko
Phase C, D.
Check your other stepper motors or disconnect motor to check.
Check pin 7 on your Gecko drive, If wire connected disconnect, Does the stepper lock up and work now (Disable Pin, Gnd to Disable Drine)
Gecko Pin 10, 5 Volts + from Arturo´s c11 board, Put a volt meter between pin 10 to pin 8, Should see 5 volts when stepping in one direction.
Let us know
Hope this Helps, Chip
« Reply #2 on: May 07, 2007, 09:55:11 AM »
Also, do you have 5 volts supplied to the enable pin on the C11 board?
SiN
« Reply #3 on: May 08, 2007, 12:25:48 AM »
Hi afn09556,
Pin 7 in gecko drive is not connected, I double checked and there are low ohms between red/white and yellow/green, Gecko's pin 10 is connected to c11's +5v and EN pin ( +5v next pin) is hard wired to 5v  power connection. Let me check 5 volts stepping voltage between pin 8 and 10  :)
Thanks Chip
                  SiN
SiN
« Reply #4 on: May 08, 2007, 12:26:51 AM »
Brett,
Yes enable pin is supplied with 5v connection.
           George
