Hello Guest it is November 22, 2026, 03:14:28 PM
Author Topic: Mach4 - 3D Printer Mode ??  (Read 11562 times)
« on: November 02, 2015, 01:06:03 PM »
3D printer mode has appeared in the latest Mach4 version... what does it mean?
Does this mean that you can use Axis E and not have to remap E-Axis (extrusion) to A-Axis?
I'm not expert at 3d having not 3d printed, but curious as to what it means (I was considering buying a printhead for my setup and giving it a go)
.... is there a manual / description on what this mode will do?
Does it do something different to the Mach3 plugin here and Slic3r?
https://cnc2printer3d.wordpress.com/software/
Rob
Rob
Re: Mach4 - 3D Printer Mode ??
« Reply #1 on: November 02, 2015, 01:07:09 PM »
I thought I read that the g-code interpreter is slightly different for 3D printer mode.
