Hello
Guest
it is
November 22, 2026, 10:05:42 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Estop after turning on spindle
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Estop after turning on spindle (Read 19880 times)
patton
92
Re: Estop after turning on spindle
Reply #10 on:
November 02, 2015, 08:40:53 PM »
bumping the Debounce up is not a fix for the problem it was only meant as a test to see if it's a noise/interference problem. you should go through your wiring and fix the noise by properly grounding and using shielded cable.
Logged
andrew.adsit
3
Reply #11 on:
November 06, 2015, 03:15:09 PM »
Agree, there are a lot of opportunities to pick up RF. The great cables from the Gecko are compromised at the motor. Need to get that shielding as close to the motor.
Sent from my iPhone using Tapatalk
Logged
Print
Pages:
1
2
Go Up
« previous
next »
