Hello Guest it is October 22, 2026, 07:42:17 PM
Author Topic: mcX360 Mach4 Controller Plugin  (Read 57436 times)
Re: mcX360 Mach4 Controller Plugin
« Reply #10 on: November 04, 2015, 07:52:08 PM »
Daz, working on Win10 using  Mach4 (2763). Thanks!
« Reply #11 on: November 04, 2015, 07:53:16 PM »
... Think I had loaded the driver on my system given you need it for m3 and the Xbox 360 controller
https://www.microsoft.com/hardware/en-gb/d/xbox-360-controller-for-windows
Rob
Rob
Albert Einstein ― “If you can't explain it to a six year old, you don't understand it yourself.”
« Reply #12 on: November 04, 2015, 08:47:04 PM »
Yes there is that dll on this system.  Any other ideas ?
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #13 on: November 05, 2015, 02:59:04 AM »
BR549 this is a long shot, the plugin is set to use controller 1, is the light on your controller in the top left?
Daz
« Reply #14 on: November 05, 2015, 08:19:29 AM »
OK Just to make sure this is CLEAR it is a Xbox360 clone.  Not a true xbox360. But it runs everything else I have tried it on.  It works the test screen in widows just fine. It runs fine with UCcnc .
There is only 1 light on the controller it is the analog ON light in between the thumb sticks.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #15 on: November 05, 2015, 09:03:01 AM »
That makes things clearer for me, i have read some code that remaps some of the internals to accommodate a clone controller. will take a look, have u a link to the controller you have and I will get one for testing.
Daz
« Reply #16 on: November 05, 2015, 10:01:57 AM »
(;-) It was a $7 xbox clone off of Amazon. Not really worth pursueing  .
Don't spend any time on this (;-) I had thought sense it ran as a HID device in windows it would be generic in nature. I guess the Plugin does not use the HID interface ??
UCcnc runs it as an HID device.
Offline Haik
  •  71 71
  • MachUser
« Reply #17 on: June 26, 2016, 05:56:09 PM »
Hello Daz,
I'm so glad that you created this plugin. I have a very big Thermwood Router, it's over 4m wide so mobility is essential. My wireless xbox controller helps make setting up a breeze, without it setups would be far more painful.
Thank You!!
- Haik
« Reply #18 on: August 05, 2016, 09:46:25 PM »
Thanks Daz for your great work . I am new to cnc machines and this will be very helpful . Works good on my LMS 3990. :)
Offline Pedio
  •  200 200
« Reply #19 on: August 19, 2016, 01:35:32 PM »
I have an Xbox One controller and it works GREAT!
Love it thanks
