Hello Guest it is November 21, 2026, 03:26:33 PM
Author Topic: MACH3 - Spindle as axis - not homing  (Read 12497 times)
« on: October 31, 2015, 06:02:42 PM »
MACH3 - Spindle set as Axis 5 (C)
Encoder feedback connected to HiCON A/A+ B/B+ Z/Z+  Verified with scope it is receiving a good signal.
Encoder feedback is displayed in Encoder 1 with Axis C set to feedback on Encoder 5
Have tried all home setting combinations, behaves same if set to sensor or index only with or without use index checked.
Have tried setting C home in Mach to the actual HiCON pin 13/3 or a phantom MACH pin.
PROBLEM: C axis will not home
PROBLEM: As soon as spindle is shut off, C axis DROs go to zero, so spindle positioning for ATC is not possible.
What is the proper config to have the spindle stop at the same spot each time?
Re: MACH3 - Spindle as axis - not homing
« Reply #1 on: November 02, 2015, 04:07:58 AM »
Answer to this is no longer needed.
Both machines have home sensors on the spindles, so I am using that instead of the encoders and its working OK.
