Hello Guest it is November 13, 2026, 05:55:01 PM
Author Topic: Probing with Pokeys57E  (Read 13297 times)
« on: October 30, 2015, 05:23:52 AM »
i think i've tried everthing, but i can't get probing work with my Pokeys 57E.
The latest pluging and sofware is installed, but probing with the command
"G31 z-20 F200" always fails with the following error message in Mach3: "probe error - overrun"
I'm running out of ideas what to try to fix the problem. >:(
Any suggestions for a proper setup?
While running my machine with the parallel port, the G31 command worked fine but I don't want to change back to it.
Greets
Phil
Offline NeoTO
  •  504 504
    • PoLabs
Re: Probing with Pokeys57E
« Reply #1 on: October 31, 2015, 12:25:28 AM »
Hi, Phil
We are currently checking what is wrong with the probing and will release the fix as soon as we find the cause.
Matevž
« Reply #2 on: November 03, 2015, 11:49:20 PM »
Thanks for the reply!
So this means there's really a problem with the Mach3 plugin?
Nobody else had trouble with the G31 command?
Does anybody have a Pokeys running the G31 command correctly?
Phil
« Reply #3 on: November 04, 2015, 12:35:34 PM »
... i forgot to mention that i use the Pokeys 57E with a PoExtBusOC16CNC extension board.
Don't know, if it's important for solving the problem?
@NeoTO:
Any news about error hunting?
Phil
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #4 on: November 16, 2015, 02:24:18 AM »
We were quite busy working on a side project and had limited time available to work on the test machines.
It took us a while to find this bug, but the solution is now available. The bug was found in rogue memory alignment of the data structure that PoKeys plugin is using to interface the device.
The update 3.1.66 is now available with the updated firmware and plugin.
