Hello Guest it is October 20, 2026, 02:52:19 PM
Author Topic: Need help. Motors dont work properly.  (Read 18426 times)
Re: Need help. Motors dont work properly.
« Reply #10 on: December 04, 2015, 03:54:50 PM »
If your drive output amps match the motor rating you do not want to reduce the amps setting as that directly reduces output torque and the motors will not burn out from the higher voltage. Higher voltage allows the drive to continue supplying the full amperage as the back emf builds up with increasing motor speed.
