Hello Guest it is November 07, 2026, 02:21:49 AM
Author Topic: 360 circle with Z drive slow down  (Read 23869 times)
« on: October 24, 2015, 06:35:45 AM »
Hello all
an question about milling a hole.
I wil like to mill a round hole of 38 mm with a milling tool of 2.6 mm that go 5 times round the circle  and that the Z access 2mm going down 0.2 mm per 360/circle.
here is my code:
but this code make a circle of 80mm and not 38mm wath's wrong?
(--38mm gat--)
G00 G17 G21 G49 G80 G90
(-- FREES 2.6MM --)
T1 M06
G00 G17 G90 G54 X0 Y0 S8000 M03
G43 H0 Z2 M08
#1 = 1.0  ( Safe Z )
#2 = -0.2 ( Engraving Depth Z )
G00 X17.7 Y40
M98 P1000 L1
G00 Z#1
G00 X17.7 Y-40
M98 P1000 L1
G00 Z#1
G00 Z20
M30
(--CONTOUR--)
O1000
G03 Z#2 F450 I0 J0
#2=[#2-0.2]
M99
Re: 360 circle with Z drive slow down
« Reply #1 on: October 24, 2015, 06:47:19 AM »
Why not just use one of the wizards to generate the code?
« Reply #2 on: October 24, 2015, 08:20:18 AM »
The wizard create code that is to lang for my DEMO of Mach3.....
« Reply #3 on: October 24, 2015, 08:58:10 AM »
Where is the center of the hole?
« Reply #4 on: October 24, 2015, 09:24:28 AM »
there are two holes with the same diameter one X0 Y40 and one X0 y-40
and the diameter is 38mm and 2 deep.
« Reply #5 on: October 24, 2015, 10:06:03 AM »
G43 H0 Z2 M08
S8000 M3
G0 Z3
G0 X0.0000 Y57.7000 Z0.1250
G1 X0.0000 Y57.7000 Z0.0000 F150
G3 X0.0000 Y57.7000 Z-0.2000 I0.0000 J-17.7000 F450
G3 X0.0000 Y57.7000 Z-0.4000 I0.0000 J-17.7000
G3 X0.0000 Y57.7000 Z-0.6000 I0.0000 J-17.7000
G3 X0.0000 Y57.7000 Z-0.8000 I0.0000 J-17.7000
G3 X0.0000 Y57.7000 Z-1.0000 I0.0000 J-17.7000
G3 X0.0000 Y57.7000 Z-1.2000 I0.0000 J-17.7000
G3 X0.0000 Y57.7000 Z-1.4000 I0.0000 J-17.7000
G3 X0.0000 Y57.7000 Z-1.6000 I0.0000 J-17.7000
G3 X0.0000 Y57.7000 Z-1.8000 I0.0000 J-17.7000
G3 X0.0000 Y57.7000 Z-2.0000 I0.0000 J-17.7000
G0 X0.0000 Y57.7000 Z3
G0 X0.0000 Y-22.3000 Z3
G1 X0.0000 Y-22.3000 Z0.0000 F150
G3 X0.0000 Y-22.3000 Z-0.2000 I0.0000 J-17.7000 F450
G3 X0.0000 Y-22.3000 Z-0.4000 I0.0000 J-17.7000
G3 X0.0000 Y-22.3000 Z-0.6000 I0.0000 J-17.7000
G3 X0.0000 Y-22.3000 Z-0.8000 I0.0000 J-17.7000
G3 X0.0000 Y-22.3000 Z-1.0000 I0.0000 J-17.7000
G3 X0.0000 Y-22.3000 Z-1.2000 I0.0000 J-17.7000
G3 X0.0000 Y-22.3000 Z-1.4000 I0.0000 J-17.7000
G3 X0.0000 Y-22.3000 Z-1.6000 I0.0000 J-17.7000
G3 X0.0000 Y-22.3000 Z-1.8000 I0.0000 J-17.7000
G3 X0.0000 Y-22.3000 Z-2.0000 I0.0000 J-17.7000
M5
M9
M30
« Reply #6 on: October 24, 2015, 10:20:55 AM »
IF you are trying to learn Parameteric Gcode I can help you . IF you are just trying to beat the Demo limit then Gerry gave you what you needed.
« Reply #7 on: October 24, 2015, 11:35:33 AM »
Br439 and Gerry thanks for the code it's forking fine but the code is not flexible. What I want is that the "L" gifs the deep in 0.2mm per circle
L10 is 2MM deep etc.
I want to gifs an X and Y value and an radius and the code make the hole.
« Reply #8 on: October 24, 2015, 12:34:41 PM »
The first thing you need to learn is HOW the I J code works with arcs . It is easiest to work in Abs code until you get to teh circles then switch to INC code  as it is much easier to deal with for circles and IJs.
« Reply #9 on: October 24, 2015, 01:43:32 PM »
(--38mm gat--)
G00 G17 G21 G49 G80 G90 G54 (Safety Block)
(Program the Parameters)
#1 = 1.0  ( Safe Z )
#3 = [38 - [2.6/2]]
#4 = #2
( Start the Process)
G00  X0 Y0
M03  S8000 M8
G00 Z#1   ( go to safeZ)
G00 X17.7 Y40  ( go to Center of circle)
G91   (Switch to INC)
G00 X#3   ( offset teh X)
G00 Z[-1*#1] ( Move to Z zero)
M98 P1000 L10   ( Call Sub, loop 10 times)
G90  ( Reset To ABS)
G00 Z#1
M30
O1000
G1 Z #4 F450
G03 X0 Y0   I [-1*#3] J0  F850
M99
