Hello Guest it is November 17, 2026, 11:01:42 PM
Author Topic: Z zero resetting at the end of a program  (Read 11249 times)
« on: October 23, 2015, 09:42:25 AM »
Odd problem with a router running mach3
At the end of a part program the cutter retracts to z.8 (zero set on top of the part) and then the program sends the machine to x and y 0.0 (lower left corner of the material) and then does a m30 to end the program.
If you look at the DRO when everything is done the Z is sitting at -1.7, which if I change to machine co-ords is what it says it should be while the x and y show the offset where the material is (3 and 3 in this case)
So it would appear that somehow at the end of the program it is resetting the z axis back to the machine value or erasing the z offset or something, but not affecting the x and y
I thought it might be from the router turning off but since it's not some random number I now think maybe no.
Z zero is being set with a tool-sense plate if that makes a difference
Any thoughts?
M
Re: Z zero resetting at the end of a program
« Reply #1 on: October 23, 2015, 12:55:01 PM »
Look in Gen Config and see IF you have any of these checked.
« Reply #2 on: October 23, 2015, 02:53:26 PM »
I ran several parts today and after each one the Z value changed but not the same each time, I originally thought it was going to machine value but it doesn't seem consistent,  it's changing each time, always on the z and always right when the program ends, after it goes to it's x/y zero
I checked the general config screen and they have "perform G92.1", "Turn off spindle" and "radius comp off" all checked
What exactly the perform G92.1 do?
M
« Reply #3 on: October 23, 2015, 03:46:10 PM »
(;-) UNCHECK them. I would leave on turn off all ouputs.
