Hello Guest it is October 20, 2026, 02:56:05 PM
Author Topic: Strange behaviour slow jog dro with encoder mapped to it. (pokeys57E)  (Read 9216 times)
I am working on a screenset for our plasma cutter.
I have to small encoders mapped on the pokeys to DRO821 (feedrate override) and to DRO3 (slow jog)
The encoders are working normal, I can change both overrides with it, but...
When mach3 starts the FRO is at 100% the slow jog is also at 100% but when I turn the encoder it goes to 1% first.
And what is also strange, I have small encoders with integrated pushbutton. I use the pushbutton to reset the overrides to 100%.
For the feedrate override this works perfect, for the slow jog is doesn't. When I press the button I sometimes see the value 100 very quick and then jumps back to original value.
If I go to the pokeys plugin and cancel te encoder mapping to Slow Jog dro, then the button works the way I want.
Anyone have any idea?
Is there a other dro I can use for this?
Sascha
Re: Strange behaviour slow jog dro with encoder mapped to it. (pokeys57E)
« Reply #1 on: October 21, 2015, 12:48:42 PM »
Dro3 is the Z axis Dro is that what you intended ?
« Reply #2 on: October 21, 2015, 02:55:02 PM »
If you talk about the standard dro's it is the A, not Z.
I meant OEMDRO 3 offcourse.
« Reply #3 on: October 21, 2015, 04:05:05 PM »
IF you are trying to do RRO for rapids I believe that DRO is OEMDRO 223.
