Hello Guest it is October 21, 2026, 01:39:22 AM
Author Topic: M9999  (Read 26199 times)
Offline rcaffin
  •  1,073 1,073
M9999
« on: October 20, 2015, 05:31:02 AM »
Way back in 2009 there was some discussion about a macro m9999 which would allow
#3=3
o100
G0 X#3
#3=[#3+1]
M9999 (If (GetVAR(3) > 6) Then Code" (END M9999)" Else code"M98 P100 " )
m30
But of course this gets thrown out because it has a nested comment (or two or three).
It's also recursive, which might upset Mach3 something awful!
Did this ever come to anything?
Roger
Re: M9999
« Reply #1 on: October 20, 2015, 06:24:10 AM »
Mach3 does not support If..Then in g-code.
Re: M9999
« Reply #2 on: October 20, 2015, 08:23:51 AM »
That looks like some of my doings. The code to the right of the  M9999 would be contained inside of the M9999. It is a way of doing conditional Gcode with mach3.
That method works fine by the way.
Offline rcaffin
  •  1,073 1,073
Re: M9999
« Reply #3 on: October 20, 2015, 04:15:58 PM »
Hi Ger and Terry
OK, so that was a cryptic shorthand method of suggesting what should be in the macro? OK, understood. Been there and done that already.
Yes, I know Mach does not support the IF statement - at least not officially. But since Mach does support some non-linear mathematical functions, you CAN create code which implements the IF concept. Been there and done that too.
Cheers and thanks
Roger
