Hello Guest it is November 10, 2026, 01:56:13 AM
Author Topic: Tool Changer Timed Out as safety  (Read 7405 times)
Offline nso
  •  36 36
« on: October 18, 2015, 02:56:10 PM »
hi everyone
i need to add a macro as( time out) also i have tried to write something but that isn't worked...anyway i need to help
'ToolChange Macro For milling machine (liner type)
Sub Main()
OldTool = GetOEMDRO (1200) 'Tool In spindle DRO You must add this to your settings screen
x = GetToolChangeStart( 0 )
y = GetToolChangeStart( 1 )
z = GetToolChangeStart( 2 )
tool = GetSelectedTool()
NewTool = tool
'Tool Changer Macro (Bed Type)
MaxToolNum = 2      'Max number off tools for the changer
ToolDown   = -60 'Z Pos to Get or drop a tool
ToolUp     = 0   'Z Hieght to Rapid from tool to tool
If NewTool = OldTool Then
   Exit Sub
End If
While NewTool > MaxToolNum
NewTool = Question ("Enter New Tool Number up to " & MaxToolNum)
Wend
Code "G00 G53 Z" & ToolUp
While IsMoving()
Wend
Call MovePos(OldTool)
While IsMoving()
Wend
Code "G53 Z" & ToolDown
Code "G4 P.1"
While IsMoving()
Wend
Do                                                 'Start loop
ActivateSignal(Output2)                   'This is signal to activate  drawbar
If IsActive (Input1) Then Exit Do        'This is a  signal to say drawbar has released
Loop
Code "G53 Z" & ToolUp
Call MovePos(NewTool)
While IsMoving()
Wend
Code "G4 P.1"
While IsMoving()
Wend
DeActivateSignal(Output2) 'Turn Off Draw bar to Clamp the tool
Code "G4 P4.1"    'Wait for the tool to Clamp
While IsMoving()
Wend
its good but i think not enough ,i need something like this: if (input 2 ) not active after a time (10 ms) then show a (msgbox "tool isn't locked "   ) then active (emergency )
Do                                                 'Start loop
If IsActive (Input2)  Then  Exit Do      'This is a signal to say tool locked correctly
Loop
Call SetUserDRO (1200,NewTool)
SetCurrentTool( NewTool )
Code "G00 X" & x & " Y" & y 'Move back to where the tool change was prompted
End Sub
Sub MovePos(ByVal ToolNumber As Integer)
Select Case ToolNumber
       Case Is = 1
         Xpos = 10
         YPos = 10
       Case Is = 2
         Xpos = 20
         YPos = 20
End Select
Code "G53 X" & XPos & " Y" & YPos
End Sub
Main
Re: Tool Changer Timed Out as safety
« Reply #1 on: October 18, 2015, 03:42:17 PM »
Lcnt = 0        ' Set loop Counter to Zero
Do   while   isactive( input2)  = false       'Start loop
Lcnt = (Lcnt+1)                                  ' Add to counter
If Lcnt >= 1000 then                           ' Check for max count, if then do
DoButton(3)
MsgBox(" Tool Change Timed Out ")       ' Notify Operator  Or use Message" Tool Changer timed out" to write to the status line
END
End if
Loop
Offline nso
  •  36 36
« Reply #2 on: October 18, 2015, 11:00:09 PM »
thanks a million dear BR549,that was what i need exactly also worked great   :)
Sub Main()
NewTool = tool
   Exit Sub
End If
Wend
While IsMoving()
Wend
While IsMoving()
Wend
Code "G4 P.01"
While IsMoving()
Wend
just for make sure the input 1 worked rightly at defined time because sometime the air pressure might isn't enough  so, i tried to do something like that here but didn't work    :-\
Do                                                 'Start loop
ActivateSignal(Output2)                   'This is signal to activate your drawbar
If IsActive (Input1) Then Exit Do        'This is your  signal to say drawbar has released
Loop
While IsMoving()
Wend
Code "G4 P.01"
While IsMoving()
Wend
Code "G4 P4.01"    'Wait for the tool to Clamp
While IsMoving()
Wend
Do   While   isactive( input2)  = false       'Start loop
If Lcnt >= 1000 Then                           ' Check for max count, if then do
DooemButton(1021)
MsgBox(" Tool Change Timed Out/ tool isn't clamped correctly")       ' Notify Operator  Or use Message" Tool Changer timed out" to write to the status line
End
End If
Loop
End Sub
       Case Is = 1
         Xpos = 10
         YPos = 10
       Case Is = 2
         Xpos = 20
         YPos = 20
End Select
End Sub
Main
« Last Edit: October 18, 2015, 11:09:43 PM by nso »
