Hello Guest it is November 10, 2026, 01:52:23 AM
Author Topic: I am having a sleep problem :)!~ CNC LATHE tool changer macro  (Read 9390 times)
Offline mike^3
  •  116 116
« on: October 17, 2015, 05:00:28 PM »
Hi everyone! you are all great! I appreciate all help. Im getting really frustrated with this...  ??? ??? ???
Heres my problem, in this macro the second wait command does not happen, even though I think it is written properly. Please take a look
Here is the code that I have, it works fine but it will not wait after it senses the right input, I put ****** by it...
I only added the ****** for the first two cases, but not the rest, its the same thing for the rest. Perhaps the wait commands are not put in properly?
The first whileismoving() works fine but the second one does not work, it doesnt even wait... Any ideas?
'Macro ATC turret V2.02.01
Sub MovePos(ByVal ToolNumber As Integer)
OldTool = GetCurrentTool()
NewTool = GetSelectedTool()
ToolNumber = NewTool
If NewTool = OldTool Then
Message" Same Tool, NO ACTION"
End
End If
If NewTool > 8 Or NewTool < 1 Then
MsgBox" Tool # Not a Valid Number 1-8 ONLY, ENDING Program RUN "
DoButton(3)
End
End If
Tcount = 0
Select Case ToolNumber 'Position to each tool number by input signal
Case = 1
Message" Select Tool #1 "
ActivateSignal(Output5) 'Releases stop dog
While IsMoving()
Sleep 1000 ******************it will wait here fine...
Wend
ActivateSignal(Output6) 'Start Turret
Tcnt = 0
Do Until GetOemLed(821) = true And GetOemLed(822) = false And GetOemLed(823) = false And GetOemLed(824) = false Or Tcnt > 200000
Tcnt = (Tcnt+1)
Loop
If Tcnt >= 200000 Then
DoButton(3)
DeActivateSignal(Output5) 'Stopping turret
DeActivateSignal(Output6) 'Lowering and stopping air motor
MsgBox" Tool Turret Timed Out not receieving input signal from turret encoder"
End
Else
DeActivateSignal(Output5) 'Trigger Stop Dawg
Message"Triggering Stop Dawg"
While IsMoving()
Sleep 2000 **********************It does not wait here for some reason***************
Wend
Message"Lowering and stopping air motor"
End If
Tcnt2 = 0
Do Until isactive(29) ' Check for reseating of turret
Tcnt2 = (Tcnt2 +1)
If Tcnt2 > = 10000 Then
DoButton(3)
MsgBox(" Turret Timed Out and Did Not Reseat")
End
End If
Loop
message " Tool #1 Loaded"
Case = 2
Message" Select Tool #2 "
While IsMoving()
Sleep 1000 *************waits ok
Wend
Tcnt = 0
Do Until GetOemLed(821) = false And GetOemLed(822) = true And GetOemLed(823) = false And GetOemLed(824) = false Or Tcnt > 200000
Tcnt = (Tcnt+1)
Loop
DoButton(3)
End
Else
While IsMoving()
Sleep 2000  **********************it does not wait
Wend
End If
Tcnt2 = 0
Tcnt2 = (Tcnt2 +1)
DoButton(3)
End
End If
Loop
message " Tool #2 Loaded"
Case = 3
Message" Select Tool #3 "
While IsMoving()
Sleep 1000
Wend
Tcnt = 0
Do Until GetOemLed(821) = true And GetOemLed(822) = true And GetOemLed(823) = false And GetOemLed(824) = false Or Tcnt > 200000
Tcnt = (Tcnt+1)
Loop
DoButton(3)
End
Else
While IsMoving()
Sleep 2000
Wend
End If
Tcnt2 = 0
Tcnt2 = (Tcnt2 +1)
DoButton(3)
End
End If
Loop
message " Tool #3 Loaded"
Case = 4
Message" Select Tool #4 "
While IsMoving()
Sleep 1000
Wend
Tcnt = 0
Do Until GetOemLed(821) = false And GetOemLed(822) = false And GetOemLed(823) = true And GetOemLed(824) = false Or Tcnt > 200000
Tcnt = (Tcnt+1)
Loop
DoButton(3)
End
Else
While IsMoving()
Sleep 2000
Wend
End If
Tcnt2 = 0
Tcnt2 = (Tcnt2 +1)
DoButton(3)
End
End If
Loop
Message " Tool #4 Loaded"
Case = 5
Message" Select Tool #5 "
While IsMoving()
Sleep 1000
Wend
Tcnt = 0
Do Until GetOemLed(821) = true And GetOemLed(822) = false And GetOemLed(823) = true And GetOemLed(824) = false Or Tcnt > 200000
Tcnt = (Tcnt+1)
Loop
DoButton(3)
End
Else
While IsMoving()
Sleep 2000
Wend
End If
Tcnt2 = 0
Tcnt2 = (Tcnt2 +1)
DoButton(3)
End
End If
Loop
message " Tool #5 Loaded"
Case = 6
Message" Select Tool #6 "
While IsMoving()
Sleep 1000
Wend
Tcnt = 0
Do Until GetOemLed(821) = false And GetOemLed(822) = true And GetOemLed(823) = true And GetOemLed(824) = false Or Tcnt > 200000
Tcnt = (Tcnt+1)
Loop
DoButton(3)
End
Else
While IsMoving()
Sleep 2000
Wend
End If
Tcnt2 = 0
Tcnt2 = (Tcnt2 +1)
DoButton(3)
End
End If
Loop
message " Tool #6 Loaded"
Case = 7
Message" Select Tool #7 "
While IsMoving()
Sleep 1000
Wend
Tcnt = 0
Do Until GetOemLed(821) = true And GetOemLed(822) = true And GetOemLed(823) = true And GetOemLed(824) = false Or Tcnt > 200000
Tcnt = (Tcnt+1)
Loop
DoButton(3)
End
Else
While IsMoving()
Sleep 2000
Wend
End If
Tcnt2 = 0
Tcnt2 = (Tcnt2 +1)
DoButton(3)
End
End If
Loop
message " Tool #7 Loaded"
Case = 8
Message" Select Tool #8 "
While IsMoving()
Sleep 1000
Wend
Tcnt = 0
Do Until GetOemLed(821) = false And GetOemLed(822) = false And GetOemLed(823) = false And GetOemLed(824) = true Or Tcnt > 200000
Tcnt = (Tcnt+1)
Loop
DoButton(3)
End
Else
While IsMoving()
Sleep 2000
Wend
End If
Tcnt2 = 0
Tcnt2 = (Tcnt2 +1)
DoButton(3)
End
End If
Loop
message " Tool #8 Loaded"
End Select
SetOemDro(824,NewTool)
End Sub
End
Offline TPS
  •  2,627 2,627
Re: I am having a sleep problem :)!~ CNC LATHE tool changer macro
« Reply #1 on: October 18, 2015, 02:53:41 AM »
While IsMoving()
Wend
is only used if any axis is moving (XYZABC)
so:
Code: [Select]
While IsMoving()
Wend
should be:
Code: [Select]
Thomas
Offline mike^3
  •  116 116
« Reply #2 on: October 18, 2015, 05:32:30 AM »
I tried that doesn't work....it still does not pause after deactivating output 5....any other wait functions?
Offline mike^3
  •  116 116
« Reply #3 on: October 18, 2015, 06:44:03 AM »
I got the pause to work properly by removing the while and wend functions!
But the turret is still not changing to the right positions,
heres a video
https://www.youtube.com/watch?v=sK_UEFM9VtQ
Offline TPS
  •  2,627 2,627
« Reply #4 on: October 18, 2015, 06:48:24 AM »
you are "dancing" on two parties (threads) now.
have a look for the origin thread.
  •  9,376 9,376
« Reply #5 on: October 18, 2015, 09:49:44 AM »
It's certainly very confusing with two threads running on the same subject.  ???
Please continue this discussion here;   http://www.machsupport.com/forum/index.php/topic,30989.msg215501.html#new
