Hello Guest it is November 13, 2026, 05:10:44 PM
Author Topic: Pokeys57CNC switch pin Mach3  (Read 22248 times)
« on: October 16, 2015, 07:06:01 AM »
I use Mach3 an Pokeys57CNC.
 I can not find the link between the SWITCH pin connector and pin number configuration. What should I set pin using the Swicth card connector.
Thanks for your help
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys57CNC switch pin Mach3
« Reply #1 on: October 16, 2015, 01:43:18 PM »
PoKeys57CNC uses 'dedicated I/O' pins, so the switch input pins do not behave like regular PoKeys pins.
When configuring Pulse engine in Mach3 plugin settings, 'External 4ch with IO' option must be selected and 'Dedicated limit/home' option must be selected for the axes pins.
« Reply #2 on: October 21, 2015, 03:07:16 AM »
Hi NeoTo,
Thanks for your answer.
I had not selected the pin 0 on 3 axes in Pokeys configuration software, homing working properly but with a very basic speed.
I always have trouble with probing, the switch probe is well recognized in Mach3. Digitalize the led shows the manual activity on the switch probe, but the command GCODE G31 Z-50 has no effect on the Z axis, the axis does not move.
Is there another command to perform the probing?
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: October 21, 2015, 10:43:11 PM »
The homing speed is configured in Mach3 configuration (Homing/Limits diagram).
Regarding probing - did you try to change the polarity of the probe input (Invert option in PoKeys plugin settings)? Does Mach3 display any error on executing G31?
« Reply #4 on: October 23, 2015, 05:14:30 AM »
- When I increase the homing speed on the X and Y axes, I exceed the home switch and stop the limit switch.
- The G31 command forwarding me the error: Probe error - overrun
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #5 on: October 23, 2015, 06:46:17 AM »
What are the values of the motion parameters you use?
Regarding the G31 - did you try to invert the probe signal as I suggested earlier?
« Reply #6 on: October 23, 2015, 08:24:25 AM »
When y try to invert the probe signal, i get the message: Probe Ignore. actived at call for probe.
where find the motion parameter ?
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #7 on: October 24, 2015, 01:06:24 AM »
The motion parameters are configured in Mach3's dialog (steps per unit, max. velocity, acceleration...)
Write the complete G31 command here.
Can you check that you are running the latest Mach3 version (R3.043.066) and the latest PoKeys software and firmware?
« Reply #8 on: October 24, 2015, 01:16:08 AM »
For the Z axis : Step = 160.2605863  velocity : 3000 and acc : 496.06707
The command is in MDI : G31 Z-100
The version of Mach3 is the latest an licenced, idem for Pokeys , the version of software is 3.1.65 and firmware 4.1.41
« Reply #9 on: October 29, 2015, 01:02:02 PM »
got exactly the same problem with my PoKeys57E.
Installed the latest firmware for Pokeys.
Regardless, probing command G31 Z-100 F200 always fails with the message: "Probe error - overrun" >:(
Need help!
Phill
