Hello Guest it is November 22, 2026, 02:10:14 PM
Author Topic: HOTKEY TO OUTPUT RELAY  (Read 21565 times)
Offline DAS
  •  21 21
« on: October 13, 2015, 10:58:08 AM »
Hi all
I think this has been asked before but here goes again. I would like to set a hotkey to activate an output relay. I would like to replace or reuse one of the existing screen buttons re name it and have it activate an output relay only while the key or button is pushed. I have already done the button  in screen 4 now I need to know how to program it. I assume it needs a code installed in VB Script???? That's where I am stuck. code output  active and output deactivate   where does the code go and how do find where I put it and make it work  my output pin.
I have a keyboard full of keys to use do not really want to install a bank of switches
HELP PLEASE  DAS
Re: HOTKEY TO OUTPUT RELAY
« Reply #1 on: October 14, 2015, 06:42:09 AM »
Looks like alt C is tied to the coolant so, could you not setup your output to the coolant and use that?
Offline DAS
  •  21 21
« Reply #2 on: October 14, 2015, 07:28:41 AM »
Hi All
the 3 available pre programmed outputs  coolant, mist and spindle ccw buttons are all in use. still need a couple more.
Thanks  DAS
Offline TPS
  •  2,627 2,627
« Reply #3 on: October 15, 2015, 02:52:32 AM »
Hi Das,
put this little script into the button
'GetOEMLed(77) -> Output4
'GetOEMLed(78) -> Output5
'GetOEMLed(79) -> Output6
If GetOEMLed(79) Then
   DeActivateSignal(Output6)
Else
End If
but dont forget to activate the output in port's & pin's
Thomas
Offline DAS
  •  21 21
« Reply #4 on: October 15, 2015, 07:52:18 AM »
Thanks   TPS  The code works great turns it on and off  I also need a momentary contact.  do you have a code for that.
really appreciate the info  I can build a machine  but programming codes are beyond me.
Thanks  DAS
Offline TPS
  •  2,627 2,627
« Reply #5 on: October 15, 2015, 07:58:56 AM »
Hello DAS,
as far i know, it is not possible to switch a output only while the key is pressed.
the macro is only trigged once when the key is pressed, not when the key ist released.
for the moment i know no way to realise this.
Thomas
Offline DAS
  •  21 21
« Reply #6 on: October 15, 2015, 10:16:23 AM »
I DID find a code somewhere that was for on and off but of course cant find it when you need it.Is it possible to have a code  input  4 on and then  a delay of around 5 seconds and then turn off  without pressing the button again??
Thanks   DAS
Offline DAS
  •  21 21
« Reply #7 on: October 15, 2015, 12:31:01 PM »
Hi All Sorry output 4 not input 4
DAS
Offline TPS
  •  2,627 2,627
« Reply #8 on: October 16, 2015, 02:22:59 AM »
OK,
put this code in macropump script:
Code: [Select]
If GetOEMLed(77) then ' Output4 is on
    If Timer - GetOEMDRO(1500) > 5 then
        DeActivateSignal(Output4)
    End if
Else
    SetOEMDRO(1500,Timer)
End If
make sure macropump is enabled in general config
restart Mach
Thomas
Offline DAS
  •  21 21
« Reply #9 on: October 16, 2015, 12:15:11 PM »
Hi TPS  tried the code even on 2 machines   it did nothing. what am I doing wrong.
DAS
