Hello Guest it is November 22, 2026, 02:27:55 PM
Author Topic: CNC Lathe turret tool changer help?  (Read 79212 times)
Offline TPS
  •  2,627 2,627
Re: CNC Lathe turret tool changer help?
« Reply #60 on: October 19, 2015, 07:55:10 AM »
Ok let's try and error
please change
    'look for OEMTRIG1
    If Not IsActive(OEMTRIG1) Then
to
    'look for OEMTRIG1
    If IsActive(OEMTRIG1) = False Then
should be the same put try please.
Thomas
Offline mike^3
  •  116 116
« Reply #61 on: October 19, 2015, 08:01:28 AM »
WORKs!
Here Is my final code, I cant thank you enough! THANK YOU!
Sub Main()
' TPS 19.10.2015
' Toolchange for a 8 place turret (single step)
' V 5.0.1
' pin2 is mapped to Input1
' pin3 is mapped to Input2
' pin4 is mapped to Input3
' pin5 is mapped to Input4
' charger seated is mapped to OEMTRIG1
'get the new tool ---------------------------------------------------------------
tool = GetSelectedTool()
' nothing to do
If GetSelectedTool() = GetCurrentTool() Then
     message("Tool is the same NO tool change needed")
   End
End If
If  tool > 8 Or tool < 1 Then 'check tool number to be in range
    Message (" Tool " & tool & " is not a valid Number 1-8 ONLY, ENDING Program RUN ")
    DoButton(3)
    End
End If
tryagain:
'get actual starttime
Starttime = Timer
Message "Moving to Tool# " &GetselectedTool()
   Akttime = Timer
   While Akttime - Starttime < 50 'try until timeout
    ActivateSignal(OutPut5)  'unlocks stop dog
    Sleep(100)              'wait for a second
    ActivateSignal(OutPut6)  'turn air motor on
    DeActivateSignal(OutPut5)    'locks stop dog
    Sleep(200)              'wait for a second
    DeActivateSignal(OutPut6)    'turn air motor off
    Sleep(300)
    'check the position
    If GetTurret() = tool Then
       GoTo finished
    End If
    Akttime = Timer
    If Akttime - Starttime > 40 Then 'Timeout 20s
       Message("Turret timeout")
       DeActivateSignal(output5)    'locks stop dog
       Sleep(1000)                  'wait for a second
       End
    End If
   Wend
finished:
   'recheck the turretpos and retry
   If  GetTurret() <> tool Then
        GoTo tryagain
   End If
    'look for OEMTRIG1
    If Not IsActive(OEMTRIG1) = false Then
        DOButton(3)
        MsgBox("Tool changer not seated!")
        End
    End If
    Message("Tool " & tool & " Loaded")
    SetCurrentTool( tool )
End Sub
'function to get the actual turret position
Function GetTurret() As Long
   GetTurret = 0
    If IsActive(Input1) Then
        GetTurret = GetTurret + 1
    End If
    If IsActive(Input2) Then
        GetTurret = GetTurret + 2
    End If
    If IsActive(Input3) Then
        GetTurret = GetTurret + 4
    End If
    If IsActive(Input4) Then
        GetTurret = GetTurret + 8
    End If
End Function
Offline TPS
  •  2,627 2,627
« Reply #62 on: October 19, 2015, 08:21:46 AM »
Ok,
sounds good.
Thomas
Offline mike^3
  •  116 116
« Reply #63 on: October 19, 2015, 08:40:04 AM »
