Hello Guest it is November 10, 2026, 02:33:54 AM
Author Topic: CNC Lathe turret tool changer help?  (Read 78530 times)
Offline mike^3
  •  116 116
Re: CNC Lathe turret tool changer help?
« Reply #10 on: October 09, 2015, 08:17:50 AM »
Thanks will try it soon!
Offline mike^3
  •  116 116
« Reply #11 on: October 09, 2015, 12:05:48 PM »
Seems to be working great here, can you put in 2 things?
1. There is a switch (oemtrigger1) when it is active low the turret is not seating properly, can you put this in after each tool change, if it does not sense the HI then try again, but if it does not sense the HI then estop the machine and msg box "Turret not seating!"
2. Can you put an estop in after ther turret timeout, to 3stop the machine? and msg box "Turret could not find tool ESTOP machine"?
You are awesome my friend!!
Offline TPS
  •  2,627 2,627
« Reply #12 on: October 09, 2015, 02:07:55 PM »
ok,
maybe tomorrow.
Offline mike^3
  •  116 116
« Reply #13 on: October 09, 2015, 02:35:18 PM »
Sweet thank u, I'll try it on my lathe shortly and upload a vid! ;)
Offline mike^3
  •  116 116
« Reply #14 on: October 10, 2015, 06:45:49 AM »
Hi TPS, I am running into a challenge, I cant get the turret to stop accurately
...So...I was thinking... can we put a deactivate output 5 before the deactivate output 6 with a time delay (that I can adjust)?
So that when output 5 disables (engages the stop dog) keep output 6 active for like 1 second until the stop dog stops the turret.
The stop dog is NOT a pin, its like a finger, and when output 5 is disabled...the finger grabs onto the bottom turret and when the turret spins, it will then stop to the next tool. Then we can deactive output 6 (after 1 second), which stops the air and drops the turret (the finger from the stopdog will stop the turret, and then output 6 will just stop the air to the air motor and then drop the turret)
I believe this will make it work perfectly...
So...
activate output 5 ' unlocks stop dog
wait for a second
activate output 6 ' raises turret and spins
wait for case command
when case is true for right tool
deactivate output 5 'locks the stop dog
wait 1 second
then
deactivate output 6 ' stops the turret and lowers it
continue program...
:D
Could we put this in? Along with estop and time outs?
Is there anything I can do in return for your help?
Thank you!
Offline TPS
  •  2,627 2,627
« Reply #15 on: October 12, 2015, 01:25:22 AM »
ok here with stop dog
Code: [Select]
Sub Main()
' TPS 09.10.2015
' simple Test for Toolchange
' pin2 is mapped to Input1
' pin3 is mapped to Input2
' pin4 is mapped to Input3
' pin5 is mapped to Input4
'get the new tool ---------------------------------------------------------------
tool = GetSelectedTool()
' nothing to do
If GetSelectedTool() = GetCurrentTool() Then
     message("Tool is the same NO tool change needed")
   END
End If
Dim ActTurretPos as long
ActTurretPos = 0
'get actual starttime
Starttime = Timer
Message "Moving to Tool# " &GetselectedTool()
   ActivateSignal(output5)  'unlocks stop dog
   Sleep(1000)              'wait for a second
   ActivateSignal(OutPut6)  'turn air motor on
   While ActTurretPos <> tool 'turn until we are in the wright position
      ActTurretPos = GetTurret()
      Akttime = Timer
      If Akttime - Starttime > 20 then 'Timeout 20s
        Message("Turret timeout")
        DeActivateSignal(output5)    'locks stop dog
        DeActivateSignal(OutPut6)    'turn air otor off
        End
      End if
   Wend
    Message("Tool " & tool & " Loaded")
   SetCurrentTool( tool )
End Sub
'function to get the actual turret positiom
Function GetTurret() As Long
GetTurret = 0
    If IsActive(Input1) Then
        GetTurret = GetTurret + 1
    End if
    If IsActive(Input2) Then
        GetTurret = GetTurret + 2
    End if
    If IsActive(Input3) Then
        GetTurret = GetTurret + 4
    End if
    If IsActive(Input4) Then
        GetTurret = GetTurret + 8
    End if
End Function
Thomas
Offline mike^3
  •  116 116
« Reply #16 on: October 12, 2015, 07:05:55 AM »
That works great thomas! May I ask one last thing? Also can I paypal you some money for helping me?
1. Can I put in a command that, after output 6 deactivates wait 1 second, then the macro looks for oemtrigger1 and if it is low, then estop the machine and msgbox 'Tool changer not seated!
2. Can we put in, only tools 1-8 are valid, if >8 and <1 dont proceed, kinda like this
If  NewTool > 8 Or NewTool < 1 Then
MsgBox" Tool # not a valid Number 1-8 ONLY, ENDING Program RUN "
DoButton(3)
End
End If
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D :D :D :D :D :D :D :D :D :D :D :D
Offline TPS
  •  2,627 2,627
« Reply #17 on: October 12, 2015, 03:22:35 PM »
OK something like this should work,
oemtrigger1 is not ok input5 would be great
Code: [Select]
Sub Main()
' TPS 09.10.2015
' oemtrigger1 is mapped to input5
' nothing to do
   END
End If
If  tool > 8 Or tool < 1 Then 'check tool number to be in range
    Message (" Tool " & tool & " is not a valid Number 1-8 ONLY, ENDING Program RUN ")
    DoButton(3)
    End
End If
ActTurretPos = 0
Starttime = Timer
      Akttime = Timer
        End
      End if
   Wend
sleep(1000)
    'look for Input5
    if not IsActive(Input1) then
        DOButton(3)
        Messagebox("Tool changer not seated!")
end
    End If
End Sub
GetTurret = 0
    End if
    End if
    End if
    End if
End Function
Thomas
« Last Edit: October 12, 2015, 03:25:41 PM by TPS »
Offline mike^3
  •  116 116
« Reply #18 on: October 12, 2015, 05:48:38 PM »
I looked in mach3 for inputs and they only have inputs 1-4 that's why I mentioned oemtrigger1
Offline TPS
  •  2,627 2,627
« Reply #19 on: October 13, 2015, 03:40:56 AM »
Sorry my fault.
here the version with OEMTRIG1
Code: [Select]
Sub Main()
' TPS 09.10.2015
' charger seated is mapped to OEMTRIG1
' nothing to do
   END
End If
    DoButton(3)
    End
End If
ActTurretPos = 0
Starttime = Timer
      Akttime = Timer
        DeActivateSignal(OutPut6)    'turn air motor off
        End
      End if
   Wend
   sleep(1000)
    'look for OEMTRIG1
    if not IsActive(OEMTRIG1) then
        DOButton(3)
        End
    End If
End Sub
GetTurret = 0
    End if
    End if
    End if
    End if
End Function
« Last Edit: October 13, 2015, 03:43:01 AM by TPS »
