Hello Guest it is November 10, 2026, 01:54:55 AM
Author Topic: Mach3 Probe HELP  (Read 11459 times)
Mach3 Probe HELP
« on: October 04, 2015, 02:46:19 AM »
Hello
i need your help a little please .. i have a problem with my Mach3 Probe ... to start with i made my own probe and everything it worked fine the LED light was green when the torch touched the plate and the VBscript worked fine as well when i clicked on "ref all home" .. but heres the problem when i try to work on a file on Mach3 the probe doesnt work at all .. its like i didnt even activated it :( i tried to change the vbscript and many other things but nothing worked .... i need help if you could .. as soon as possible
thanks in advance.
Offline TPS
  •  2,627 2,627
Re: Mach3 Probe HELP
« Reply #1 on: October 05, 2015, 01:50:44 AM »
post your vbscript an we will see, but remember
the probing is only measuring the length of the
tool, nothing else.
Thomas
« Reply #2 on: October 05, 2015, 02:54:10 AM »
sorry i might have done something wrong ... but what i want is what in the following video:-
https://www.youtube.com/watch?v=ZwK58aWHsHQ
i want my plasma machine to work just like in the video shows ... if you have a map of how i should do that or a setting or wiring or a way of connecting or a VBscript anything that helps my plasma to work the same as the man's in the video ... please send it to me .. thanks.
(p.s. i did connect the limit switch with the Z axis)
Offline TPS
  •  2,627 2,627
« Reply #3 on: October 05, 2015, 03:58:52 AM »
a simple example for metric would be:
Sub Main
cutheight = 20
cutpos = 0
ZProbePos = 0
    Code "G31 Z-200 F150" 'do the probing
    While IsMoving() 'wait for finish
    Wend
    'get the position where we hit the probe
    ZProbePos = GetVar(2002)
    cutpos = ZProbePos - cutheight
    'go to cutting heigt
    code "G1 Z" + cutpos + "F100"
    'set new z-Pos
    SetDRO(2,cutheight)
End Sub
not tested, just written down.
Thomas
« Reply #4 on: October 05, 2015, 04:24:51 AM »
im sorry but the vbscript you sent didnt work ...
Offline TPS
  •  2,627 2,627
« Reply #5 on: October 05, 2015, 04:28:28 AM »
what exactly did not work ?
did you do a ref all after the probe ?
« Reply #6 on: October 05, 2015, 04:36:43 AM »
only half of it worked and then it says "Error Line:17_mismatch" and yes i did click on ref all after the probe the same error appeared .... does this script that you sent me works with every time i start a program on mach3? like does it move every time or just once only when i click on ref all??
Offline TPS
  •  2,627 2,627
« Reply #7 on: October 05, 2015, 04:53:56 AM »
ok, here the corrected version:
Sub Main
cutheight = 20
cutpos = 0
ZProbePos = 0
    Wend
    code "G1 Z" + CStr(cutpos) + "F100"
    'set new z-Pos
    SetDRO(2,cutheight)
End Sub
but the logic  sequence would be to do a ref all first,
and the run the script, because the ref Z will "destroy"
your probe height.
Thomas
