Hello Guest it is November 18, 2026, 08:53:55 AM
Author Topic: skipping steps  (Read 60997 times)
Re: skipping steps
« Reply #20 on: May 17, 2007, 05:16:17 AM »
Hi Brian,
I am running in mm mode, and I have 100 steps/mm, as on one rotation the screw is making 20 mm and I am running 200 steps/rev motors by 10 microsteppings Geko drivers.
Thank you,
Zoltan
Re: skipping steps
« Reply #21 on: May 17, 2007, 05:23:13 AM »
I am not sure did I understand right ? I think I have similar problem in last month.
What is your step and dir pulse lenght in yours settings in the "motor tuning and setup" ?
My first post, and sorry for my English  ???
Re: skipping steps
« Reply #22 on: May 17, 2007, 05:32:11 AM »
It is 5, both.
Zoltan
Re: skipping steps
« Reply #23 on: May 17, 2007, 05:34:10 AM »
Do you use any USB- devices in your PC ?
JuKa
Re: skipping steps
« Reply #24 on: May 17, 2007, 05:38:23 AM »
NO. I am planning to mount a Joystick. Jus bought one.
Zoltan
Re: skipping steps
« Reply #25 on: May 17, 2007, 09:24:32 AM »
Okay, we have had you check this but could you please post the graph that you are getting from the Driver test? I would like to see what your pulsing looks like :)
Brian
www.newfangledsolutions.com
www.machsupport.com
Re: skipping steps
« Reply #26 on: May 17, 2007, 10:09:35 AM »
I do not know how to get it?? I run the driver test and it seems very, very stable and smooth. The spikes are very small. How I can capture in a screen to post here?
Zoltan
Re: skipping steps
« Reply #27 on: May 17, 2007, 10:12:55 AM »
There is a Print screen button on your keyboard (should be over the insert key). go into paint and press Ctrl V and that will paste the screen shot into paint so you can work on it.
Hope that helps and I think the small spikes are the problem
www.machsupport.com
Re: skipping steps
« Reply #28 on: May 17, 2007, 01:07:13 PM »
Hi Brian,
I captured three screens. The first is when I first run the driver test. The other two were captured when I run the driver test second time.
Zoltan
Re: skipping steps
« Reply #29 on: May 17, 2007, 04:09:50 PM »
Please run only the drivertest and not mach 3
sorry about that
Brian
www.machsupport.com
