Hello Guest it is October 21, 2026, 02:07:57 AM
Author Topic: What all is needed to convert from emc2 to mach3?  (Read 9756 times)
« on: September 23, 2015, 02:18:36 PM »
Anyone know?
Re: What all is needed to convert from emc2 to mach3?
« Reply #1 on: September 23, 2015, 05:38:52 PM »
YEP a LOT of patience (;-) TP
  •  9,374 9,374
« Reply #2 on: September 24, 2015, 01:53:21 AM »
You could start by reading the documentation and watching some of the video's   http://www.machsupport.com/help-learning/  then if you have any specific questions regarding the setting-up and operation of Mach3 we would be pleased to provide an answer.
Offline mc
  •  384 384
« Reply #3 on: September 24, 2015, 04:15:34 PM »
It will depend on what you're actually converting.
If it's something with a parallel port, simply install windows 7 32bit or earlier, followed by Mach 3 with the parallel port driver, then it's just a case of changing the settings to suit your machine.
However, if it's something not using the parallel port, then it will depend on exactly what boards/controllers are being used.
