Hello Guest it is November 23, 2026, 01:21:57 PM
Author Topic: Can load be speeded up in my case?  (Read 8984 times)
Offline Davek0974
  •  2,606 2,606
« on: September 23, 2015, 02:51:18 AM »
Probably something i have not set right but...
When I load code, it runs through each line on screen, then when i press my "set origin" button it re-runs the whole lot again.
This can take some time on a full sheet, am i doing something odd or is this normal behaviour for Mach3??
BTW my set origin button (i think) copies the current position to a G54, then zero's the DROs then regens the toolpath display, basically makes wherever i stick the torch my zero point.
Re: Can load be speeded up in my case?
« Reply #1 on: September 23, 2015, 09:06:02 AM »
Setup your Point of origin first THEN load your program. OR just create a new button that just zeros teh XYZ. I believe if you just zero the xyz then it will not regen.
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: September 23, 2015, 09:18:09 AM »
That sounds good, thanks
