Hello Guest it is October 21, 2026, 07:04:56 AM
Author Topic: Problem with "RUN FROM HERE"  (Read 19260 times)
Re: Problem with "RUN FROM HERE"
« Reply #10 on: September 22, 2015, 05:10:08 PM »
Go to General Config and take the tick out of Use Watchdogs and see if that helps.
« Reply #11 on: September 23, 2015, 01:11:18 PM »
  Thanks Hood
      That did the trick (carnt find much on the web about watchdogs so have no idea wheat they do)
  managed to finish the job.  :)
« Reply #12 on: September 23, 2015, 02:07:52 PM »
Good you got it sorted :)
The watchdog basically is looking at your computer and if it senses any slight glitches such as slight timing issues in the driver it will trip. It is really sensitive and Art has often said to disable it if you get issues with the watchdog.
