Hello Guest it is October 26, 2026, 04:03:46 PM
Author Topic: New to this any help please  (Read 8835 times)
« on: September 14, 2015, 01:49:14 PM »
I'm looking int getting into cnc plasma cutting  r there any tetoriols yall would recommend any pointers where to start first I guess I'm asking for info you wished someone would of told u when u first started thank u all very much hope to here from a lot of people.   Thanks have a good day
Re: New to this any help please
« Reply #1 on: September 14, 2015, 08:05:35 PM »
Do you have any knowledge of CNC, CAD, CAM, etc?
« Reply #2 on: September 14, 2015, 08:36:00 PM »
Cad yes I do a lot of drawing with rhino3d
« Reply #3 on: September 15, 2015, 05:30:44 AM »
Knowing CAD will be of value.
I would recommend that you start your learning by viewing  the Mach 3 videos to get a flavor of how Mach3 is used.
Read the Mach Mill Manual.
Purchase CNC Machining Handbook by Peter Smid, read / study  the first 100 pages or so, then continue reading it for
 what applies to the Mill.
Then  go back and re- read Mill Manual and pay attention to the gcode section.
Have a look at Sheet Cam for using the Plasma and the gcode generated..
Plasma machine operates differently than a mill or router and has it's quirks. You need an understanding of how the machine
operates.
The above will move you along the learning path.
As far as a plasma machine is concerned talk to someone who has knowledge of plasma cutting.
General CNC concepts apply to all CNC machines, but as said, each machine is different in use.
Enjoy the learning, CNC is not "plug and play", and there are no short cuts, so simply said:
Know before you go
