Hello Guest it is November 22, 2026, 10:33:28 AM
Author Topic: Mach3 error`s parallel finish and roughing depth???  (Read 14877 times)
« on: September 11, 2015, 09:11:24 AM »
Hi  :)
Im new on this cnc things, but im trying very hard to get my self work on my cnc, the problem i find is this error´s of my gcode:
Fri - 15:23:37 ---Program Startup
Fri - 15:23:55 ---Driver Successfully initialised
Fri - 15:24:42 ---STOCK/BLOCK. 40.000. 35.000. 9.900. -0.000. -0.000. 9.900
Fri - 15:24:43 ---Parallel Finish
Fri - 15:24:50 ---STOCK/BLOCK. 40.000. 35.000. 9.900. -0.000. -0.000. 9.900
Fri - 15:24:50 ---TOOL/MILL.2.0000.0.11.0000.0.0
Fri - 15:24:54 ---Roughing Level Depth: -1.414
Fri - 15:25:55 ---Roughing Level Depth: -2.828
and them the machine stop working at this point.  ???
Obs: i use solidworks-----»meshcam----»mach3
Can someone pls help me??
Re: Mach3 error`s parallel finish and roughing depth???
« Reply #1 on: September 11, 2015, 09:19:09 AM »
Is it a licensed version ?
« Reply #2 on: September 11, 2015, 09:21:27 AM »
Yes i think it is, it came with the pc`s  cnc.
« Reply #3 on: September 11, 2015, 09:29:16 AM »
Click HELP / ABOUT at the top and check for your name.
« Reply #4 on: September 11, 2015, 09:33:07 AM »
It says papa  fabio
« Reply #5 on: September 11, 2015, 09:41:12 AM »
That is a pirated copy. You got ripped there. See if they will square up with ya.
Contact Newfangled for a legit lic.
« Reply #6 on: September 11, 2015, 09:47:06 AM »
Ok i will contact for a legit license,
so thats my problem? it give me these error´s because of pirated license?
« Reply #7 on: September 11, 2015, 09:53:22 AM »
very possible.
could cause a multitude of problems.
« Reply #8 on: September 11, 2015, 09:58:21 AM »
also, any comments or lines of code to be ignored need to be in (    ) or proceeded by  ;  else it will stop and throw an error which you can read in the status line at the bottom left of the screen.
Not sure how you post process is outputting the code. You might post the code for a look.
Russ
« Reply #9 on: September 11, 2015, 10:05:28 AM »
Ok i will try that, just one more question pls, im using cnc fireball 3 axis probotix v90 do you know some good mach3 config to milling 3d?
Thanks again
