Hello Guest it is September 23, 2026, 02:24:45 PM
Author Topic: Activate "Set Home Z" from G-Code possible?  (Read 19460 times)
« on: September 07, 2015, 06:47:18 AM »
I have an opto probe on the Z axis of my lathe which works great for accurately setting up a part but I'd like to automate its operation.
At the moment, I have it set up to move to the correct location but have to manually click the button on each part (standard lathe screenset at the moment)  Is there a way to activate the button from a G-code command?
Milton from Tennessee ya'll.
Re: Activate "Set Home Z" from G-Code possible?
« Reply #1 on: September 08, 2015, 12:42:45 PM »
You can do it via a custom M code.
Just open notepad, put the VB you want in then save as M101.m1s and save to your macro folder of the profile you are using.
When you call m101 from G Code it will do whatever is in the macro.
Custom macro numbering is 101 upwards.
« Reply #2 on: September 09, 2015, 07:31:40 AM »
Thanks, that makes sense.  As far as the VB code, where can I find what's "behind" the button ie: what code runs when I click it?  I tried Operator/Edit Button Script but the Set Home Z button isn't flashing/editable.  (Or am I barking up the wrong tree as Pappy used to say.)
« Reply #3 on: September 09, 2015, 07:37:06 AM »
Looking in the OEM code list it seems to be 212, so VB would be
DoOemButton(212)
« Reply #4 on: September 09, 2015, 07:37:56 AM »
Oops sorry Z you said, I gave you X, 213 is Z.
« Reply #5 on: September 09, 2015, 08:16:50 AM »
Goody, goody....can't wait to try it when I get home tonight! ;D
« Reply #6 on: September 10, 2015, 07:23:44 AM »
Well piffle, it didn't work like I planned. :'(
Instead of moving the Z towards the work at the 5% speed I have setup in the Home config screen it takes off at max jog speed.  I couldn't risk destroying the probe so I gave up for last night.  Is there a way to add some code to the macro to set the jog speed to 5%?
Offline TPS
  •  2,627 2,627
« Reply #7 on: September 11, 2015, 03:10:02 AM »
SetOEMDro(3,5) will set the slow jog speed to 5%,
but i am not sure the DoOemButton(213) will
use this speed.
Thomas
here:
http://www.machsupport.com/forum/index.php/topic,30658.msg212858.html#msg212858
i have posted a list with button's, led's and dro's.
« Last Edit: September 11, 2015, 03:18:18 AM by TPS »
« Reply #8 on: September 11, 2015, 03:53:43 PM »
Thanks, been busy all day & haven't tried it yet.  I'll try it later & see what happens.
« Reply #9 on: September 11, 2015, 04:11:35 PM »
I am not really familiar with the standard lathe screenset so I don't really know what the button in question is meant to do.
If you simply want to home the Z in the normal manner, as you would with a mill, and as I do with my own lathes, then try
DoOemButton(1024)
That should home the Z in the normal manner, ie move at the set homing speed %, trip the switch and back off until switch is closed again.
