Hello
Guest
it is
October 20, 2026, 09:44:26 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Help please....mach3 jumping to reset when i cut any deeper than 0.5mm
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Help please....mach3 jumping to reset when i cut any deeper than 0.5mm (Read 30874 times)
mikekuru
13
on:
September 03, 2015, 04:55:01 PM »
Hi, i am using a bridgeport cnc series 1 and mach3 pro..
im having to run my machine to cut at finishing depths or mach3 jumps to reset....it will cut at 0.5mm and it usually takes all day for the smallest jobs...
even cutting aluminium...ive been running it like this since Jan this year.......soon as i try cutting at proper depths......reset kicks in and i lose a couple of steps...and results in cocking the job up.
i am stumped...i have been searching the net for months looking for answers to this....i see videos on youtube of the same type of machines cutting at proper depths without a hitch...and still no answeres
thanks for listening
Mike
Logged
Re: Help please....mach3 jumping to reset when i cut any deeper than 0.5mm
Reply #1 on:
September 03, 2015, 09:25:05 PM »
Mike,
You may want to post some info on the drives, type motors ( steppers ) and size, Mach version used.
Also post your xml file that your using.
Logged
BR549
6,965
Reply #2 on:
September 03, 2015, 10:33:24 PM »
check your z upper switch they are bad about tripping due to vibration i have a series1 cnc as well. i ended up replacing the z switches in the quill housing to stop it.
Logged
mikekuru
13
Reply #3 on:
September 04, 2015, 02:19:50 PM »
thanks for the replies
i contacted Hood here on the forum he has informed me about the noise filtering,
i tried his method today and for the first time cut alu at 3mm per pass.
out of interest where did you buy the switches from?
thanks
mike
Logged
mikekuru
13
Reply #4 on:
September 06, 2015, 09:22:33 AM »
Oh well that must of been a lucky cut...tried the mill today and it stalled again in mid path.....cutting at a light rough pass with 0.5 depth sooo
i detroyed more stock and time and money.
im about to give it all up after 8 months of loss after loss after time consuming headaches....i wish i never bought this thing....its a bridgeport that wont cut aluminium....
thanks
Last Edit: September 06, 2015, 09:24:14 AM by mikekuru
Logged
Carnoustie, Scotland
Reply #5 on:
September 06, 2015, 10:13:48 AM »
Stalled? Are you meaning stalled or are you meaning it going into E-Stop?
If the latter then as a test disable your limit switches in Ports and pins and see if it helps. Remember you wont have limits so caution is needed.
Logged
mikekuru
13
Reply #6 on:
September 06, 2015, 10:58:03 AM »
Going into Estop,
ok Hood, i will disable the limit switches in ports and pins........i guess this will disable the bed and z axis limit switches then?
thanks
Mike
Logged
mikekuru
13
Reply #7 on:
September 06, 2015, 11:09:05 AM »
cant seem to find an option to....theres a pop up with ticks and crosses refering to x y and z........homing limits?
Logged
Reply #8 on:
September 06, 2015, 11:14:03 AM »
Config menu, Ports and Pins, Inputs.
Click the green tick for the X Y and Z + and - limits so that they turn to a red cross and your limits will now be disabled.
Logged
mikekuru
13
Reply #9 on:
September 06, 2015, 11:45:56 AM »
disabled them......seem to work ok....it just kept rattling the tool holder out of the chuck....and was super noisy...it didnt stop though....im cutting 7075 t6
at 3000 rpm 1272 feed at 0.5 per pass.....using 20mm 3flt hss long flute......60 stickout. with white water coolant (flood)
thanks
Mike
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
