Hello Guest it is October 22, 2026, 04:50:28 PM
Author Topic: Reading a pwm signal into Mach 3  (Read 8125 times)
« on: August 31, 2015, 03:26:32 PM »
I have an application where a want to control 4 servo motors using Mach and make their speed relative to another control system which puts out a Pwm signal, is it possible to read this into Mach? I think I can handle a script to make it adjust feedrate if I can get it into a variable.
Any ideas?.
Matt
Offline beefy
  •  138 138
Re: Reading a pwm signal into Mach 3
« Reply #1 on: September 01, 2015, 04:50:03 PM »
I would guess it can be done in a brain or macropump. A brain for instance runs 10 times a second. Will that rate of speed update be fast enough ?
Only problem is I don't know if Mach can read a PWM, though I think it can read a spindle index pulse input. Check the Mach manual for that one.
Keith.
« Last Edit: September 01, 2015, 04:55:30 PM by beefy »
