Hello
Guest
it is
August 24, 2026, 08:33:21 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
New to Mach3 - Help!
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: New to Mach3 - Help! (Read 10126 times)
Aldebaran
on:
May 02, 2007, 09:58:50 PM »
Hi.
I just installed the demo copy and already ran into troubles: how can you jog?!
Where is the Jog tab?! I can't get the pendant with the pulse generator to pop up.
Thanks.
Last Edit: May 02, 2007, 10:17:10 PM by Aldebaran
Brian Barker
3,860
Re: New to Mach3 - Help!
Reply #1 on:
May 02, 2007, 10:16:29 PM »
Please press "Tab" key to get the jog "Tab"
You can press the SHift key at the same time you press the arrow key to get max speed jog
Hope that helps
Brian
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Aldebaran
Reply #2 on:
May 02, 2007, 10:19:15 PM »
Thanks Brian.
I pressed many keys but Tab... it works now.
Print
Pages:
1
Go Up
« previous
next »
