Hello Guest it is November 13, 2026, 12:26:56 PM
Author Topic: One physical switch as end switch and ref  (Read 21059 times)
Offline Davek0974
  •  2,606 2,606
Re: One physical switch as end switch and ref
« Reply #10 on: August 30, 2015, 04:09:05 AM »
Maybe try adding some input debounce, 30-40 works on mine???
« Reply #11 on: August 30, 2015, 04:13:48 AM »
Go to Config menu then General Config and change Home SW Safety setting to the opposite of what you have and see if that helps.
Excellent, thank you very much.
No idea how I could overlook this obvious setting but this has solved the issue!
« Reply #12 on: August 30, 2015, 04:25:43 AM »
You can be excused for overlooking it as it is not what it usually does in Mach3. The CS-Labs people have used it differently and thus looking at the Mach3 manual would give you no clues :)
