Hello Guest it is October 29, 2026, 02:39:13 PM
Author Topic: XYZ have gone nuts again : MAch 3 and Chinese cnc 5040  (Read 13000 times)
« on: August 27, 2015, 12:10:31 PM »
Hello.
router have been running fine for a year or so.
But recently I started getting terrible drift on the Z axis...cutter going down an inch even on a shallow cut.
So I uninstalled and re-installed the software.
NOW it has got really bad.
Even with correct ports and pins and motor setup for my machine...the X, Y and Z arrow keys dont work the way they should.
X moves in same direction for both keys.
The Z buttons move the Y to the top when pressing either button.
And the Y buttons do nothing at all.
CAn anyone help with this?
Simon
Re: XYZ have gone nuts again : MAch 3 and Chinese cnc 5040
« Reply #1 on: August 27, 2015, 01:46:36 PM »
Do your DRO's read correctly....... when you move the X axis(or any axis) to a minus 1 inch does the DRO go to the right position?
« Reply #2 on: August 27, 2015, 02:04:35 PM »
Thanks for taking the time to reply..
Yes the readouts go up and down as they should. It's just the spindle that seems to be scrambled.
What does that mean?
« Reply #3 on: August 27, 2015, 04:14:58 PM »
I would guess the problem may not be in the mach3 software.... I would probably look into the wiring(especially ground wires since it's more than one axis) loose connections can cause all kinds of problems.... after that I would look at the  control on the machine.... maybe contact the manufacturer.
« Reply #4 on: August 28, 2015, 09:34:54 AM »
Thanks for the advice. I have cleaned everything up, and re-installed the software.
Now everything is almost OK.
If I press up and down on the arrows for the Z on the keyboard they are the wrong way round. down moves it up and vice versa.
It's a bit stutter as it moves up and down too. Perhaps a tired steppa motor?
And another odd thing....
If I load G code it seems to think that the workpiece is REALLY Small. For example if I create code for a circle of 4 inches diameter, it seems to think that the code relates to a circle that is less than an inch
IS there something I need to do to marry the code world with the physical world in the software.
Simon
« Reply #5 on: August 28, 2015, 10:39:06 AM »
Your G-Code specifies units of movement, G20 tells the controller (Mach3) it's inches, G21 mm
 - Nick
« Reply #6 on: August 28, 2015, 11:51:40 AM »
Cheers Nick...I screwed up on the units when re-installing.
That bit is fine.
Still not sure why my Z is flipped though. Pins and ports are good.
S
(No subject)
« Reply #7 on: August 31, 2015, 05:00:16 AM »
Go to config and homing/limits there is a tick or cross against reversed  change it to opposite to what you have set this will probably sort it out
Sent from my GT-I9195 using Tapatalk
