Hello Guest it is November 13, 2026, 09:51:17 AM
Author Topic: axis feeds oppisite direction after 2nd or third home  (Read 8772 times)
« on: August 26, 2015, 05:31:01 AM »
hi,
Something that has me a bit confused, my machine will home just fine a few times and next minute it will home to the limit switch then just run back to the opposite side of the machine, I then have to restart the controller and program and rehome in order to continue use, any ideas what could be causing this issue.
Re: axis feeds oppisite direction after 2nd or third home
« Reply #1 on: August 26, 2015, 06:04:05 AM »
Sounds like a faulty limit switch that is intermittently not closing when cleared. (if wired NC)
Work the switch manually (with your finger) slowly several times while watching the LED on the Diagnostics screen to see if it is intermittent in operation.
Just guessing,
Russ
« Reply #2 on: August 26, 2015, 06:07:24 AM »
thanks will give that a try.
