Hello Guest it is November 13, 2026, 05:12:24 PM
Author Topic: Mach3 and Pokeys Error Code 200702 and 9991  (Read 21947 times)
« on: August 24, 2015, 11:18:05 AM »
Dear Mach3 community
I have the following problem with the Mach 3 software .
I recently purchased the Pokeys56U . Now I wanted to configure it with my Mach3 and have for the plugin " Pokeys.dll " installed .
Now when I open Mach3 and the plugin under " Plugin Control " Configuriere , place of the Pokeys also . After Configuration says with Mach3 I need to restart the program . After the restart then comes but once an error message " Error triggred with the error number 200702 and 9991 "
Thereafter, the program crashes and I have to restart it. Then again the same error . Now I can start the program Mach3 only when I remove the USB cable from Pokeys .
Has any one of you a solution to the problem ?
Sorry for my english , I 'm from Germany
greeting
Timo
Offline NeoTO
  •  504 504
    • PoLabs
Re: Mach3 and Pokeys Error Code 200702 and 9991
« Reply #1 on: August 24, 2015, 01:28:49 PM »
Which version of Mach3 and PoKeys software are you using?
« Reply #2 on: August 24, 2015, 01:36:27 PM »
Mach 3 Version R3.043.022
Pokeys Version V3.1.56
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: August 24, 2015, 01:49:08 PM »
Update Mach3 to the latest version first. PoKeys requires it.
« Reply #4 on: August 27, 2015, 12:05:49 PM »
Thanks , now it works!
« Reply #5 on: August 28, 2015, 08:23:17 AM »
I have now but another problem .
When I installed the plugin and now in Mach3 on " Plugin Control " then go to "Configure Pokeys 56U *********xx " and then in "Pulse engine settings" tab " Integrated 3ch " configuriere and then reboot Mach3 , then the plugin inactive and get then no longer activated. That means I have to delete the plug-in and reinstall . In addition comes after the launch of Mach3 not the " window Motion Control hardware plugin sensed " so I can select Pokeys ... What am I doing wrong
greeting
Timo
« Reply #6 on: August 31, 2015, 01:38:56 PM »
nobody can help me ? :'(
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #7 on: September 05, 2015, 09:56:53 AM »
Try clearing the settings (there is PoKeysMachConfig.xml file in your Windows user AppData\Local folder, that you can delete to clear the settings of the plugin completely).
The plugin should be active on the startup of Mach3.
