Hello Guest it is November 13, 2026, 05:20:04 PM
Author Topic: Mach4 V2 + PoKeys 57E  (Read 11565 times)
« on: August 21, 2015, 01:25:31 PM »
Hello everybody.
I'm new to this Forum and so at first I want to send regards from Germany to you.
Today I installed Mach4 V2.2640 but when I tried to install the PoKeys plugin I received an error message. It said the Firmware of  the 57E needs to be updated but I'm using the latest firmware. With Mach4 V1 I had the same issue and had to'downdate' to firmware v3.1.52 to get Mach4 V1 to work but not with Mach4 V2. :'(
Does anyone use Mach4 V2 with PoKeys 57E? If so - please tell me which Versions.
best regards from Germany
Larsaf
Offline dude1
  •  1,253 1,253
Re: Mach4 V2 + PoKeys 57E
« Reply #1 on: August 21, 2015, 05:45:49 PM »
use what it says on there web site pokey version 7.8.1.2580 use M4 version 2580 the last 4 number are mach 4 version
« Reply #2 on: August 22, 2015, 03:07:47 AM »
Hi blockhead,
and thank you for your reply. I will try it and wait for builds of Mach4 V2 and PoKeys 57E that work together.
regards
Larsaf
