Hello Guest it is November 18, 2026, 09:19:20 AM
Author Topic: Floating MDI Panel V1  (Read 26491 times)
Offline DazTheGas
  •  778 778
  • DazTheGas
« on: August 20, 2015, 09:15:32 AM »
V1 of a floating mdi panel.
:Instructions
1. Create a button and in the left up script place
Code: [Select]
package.path = mc.mcCntlGetMachDir(inst) .. "\\Profiles\\" .. mc.mcProfileGetName(inst) .. "\\Modules\\?.mcc;"
DTG_Widget = require "DTG_MDI"
DTG_Widget.LoadMDI(1000,300)
2. Copy into your profiles/modules directory the attached file DTG_MDI.mcc file.
You can change the panel size with the loadMDI function ie: DTG_Widget.LoadMDI(500,300) will give you a panel of 500 x 300 etc
Offline dude1
  •  1,253 1,253
Re: Floating MDI Panel V1
« Reply #1 on: August 20, 2015, 05:04:23 PM »
well done daz works good
« Reply #2 on: August 20, 2015, 09:07:43 PM »
Big Thanks for all the info your sharing.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #3 on: August 22, 2015, 09:45:15 AM »
As of Mach4 V2 the modules directory has now been moved out of individual profile directories and moved to the root directory. This allows all profiles to access the modules and makes it easier for installers etc, Thanks for the heads up Brett..
The DTG_MDI.mcc file will now need to be moved to root/Modules and the loader script changed to
Code: [Select]
package.path = mc.mcCntlGetMachDir(inst) .. "\\Modules\\?.mcc;"
DazTheGas
« Reply #4 on: August 22, 2015, 10:30:24 AM »
No problem Daz, thanks for posting!
