Hello Guest it is November 13, 2026, 03:01:59 PM
Author Topic: DS26C31 Power Malfunction Error  (Read 9092 times)
« on: August 19, 2015, 09:51:13 AM »
The first time I plugged my PC loaded with Mach3 into my CSMIO IP/A controller, and then pressed the RESET screen button, I get the DS26C31 Power Malfunction Error box appear
Anyone know wht this means and how I fix it?
I have tried it with another PC and it gave the same problem.
The Ethernet connection is working as I can Ping the controller from the PC. And the firmware download was fine too.
It is just the Mach3 interface that appears to having a problem.
Many thanks
Mark
Re: DS26C31 Power Malfunction Error
« Reply #1 on: August 20, 2015, 02:55:07 PM »
Hi Mark
I had a similar problem recently with my CSMIO/A which suspect was caused by the 24V input voltage. My machine (Morbidelli Author 504) used a three phase half wave rectifier to produce "24V", ie it wasn't regulated, so would peak to well over 24V, possibly to close to the 30V max.
I wound up sending the controller back to CS-Labs in Poland for repair, which they turned around quickly and at no cost. Meanwhile I installed a 24V DC switchmode supply in the machine to provide true regulated 24V DC.
When the controller came back it worked first time.
Hope that helps.
regards,
Andrew
