Hello Guest it is September 28, 2026, 01:24:30 AM
Author Topic: Mach 3 USB Output  (Read 10411 times)
Mach 3 USB Output
« on: August 13, 2015, 11:38:08 PM »
Does Mach3 output something via USB? I see a lot of these Chinese USB breakout boards "http://www.ebay.com/itm/Upgraded-5-Axis-CNC-Breakout-Board-for-Stepper-Motor-Driver-Mach3-USB-Cable-/310702269807?hash=item48574c656f" which seem interesting.
I only care about outputs. This computer is only being used to debug my stepper motor drivers, not run my actual CNC machine (which has a printer port).
Thanks!
Re: Mach 3 USB Output
« Reply #1 on: August 14, 2015, 04:17:13 AM »
The reason these BoBs have a USB port is usually just to provide a +5V computer reference supply for the opto-isolators.  They do not process any signals on the USB port and indeed don't look at the data signals at all.
« Reply #2 on: August 14, 2015, 05:47:44 PM »
I don't agree. I have a Xulifeng BOB that has 4 axes plus digital I/O also a Pokeys 56U that has 55 configurable I/O.
Both have drivers for Mach3.
Hope this helps.
Mach 3 USB Output
« Reply #3 on: August 15, 2015, 08:29:39 AM »
You miss my point.  The item to which the OP linked is clearly a parallel port BoB, and it says that USB is for power.  At least two other types of BoB are the same, I have one of each.  Yes Mach can output via USB with a suitable driver, but not to this board.
Sent from my iPad using Tapatalk
« Reply #4 on: August 15, 2015, 11:41:35 PM »
sorry I read it too quick, misunderstood you
