Hello Guest it is November 13, 2026, 09:45:28 AM
Author Topic: emergency stop  (Read 19419 times)
rswolff
Re: emergency stop
« Reply #10 on: August 17, 2015, 04:33:19 PM »
to geh7552
I agree.....floating inputs are bad......
If you read one of the previous posts I had tested by connecting the input(s) to common (0v). The power supply commons are also connected to ground. I also tested by connecting to 24v. The input is non floating in both instances and neither corrected the issue.
Re: emergency stop
« Reply #11 on: August 17, 2015, 06:51:11 PM »
Either general config or ports and pins
