Hello Guest it is September 28, 2026, 01:35:14 PM
Author Topic: Tool Table is not saved when using SetToolParam() ?  (Read 14787 times)
« on: August 11, 2015, 02:16:07 PM »
Dear All.
I wrote a script that picks up my tools from 1-8, moves to a fixed probe plate, probes each tool, twice.
Then I update the Tool length offset with: SetToolParam(x, 2, yy.yyy)
Now the Tool length offset DRO is updated, and if I open up the tool database, then all tool length offsets are correct.
When I exit MACH3, I'm NOT promted to save the Tool Table, and all changes are lost.
Only if I manually update the DRO and/or manually change in the Tool Table.
Then I'm being prompted to save the Tool Table.
Is there a checkmark I missed in a menu somewhere, or is this a know bug or ?
Offline TPS
  •  2,627 2,627
Re: Tool Table is not saved when using SetToolParam() ?
« Reply #1 on: August 11, 2015, 02:55:10 PM »
DoOEMButton(316)
is your friend.
Thomas
« Reply #2 on: August 11, 2015, 03:00:29 PM »
DoOEMButton(316)
is your friend.
Thomas
The good old 316, yeah. How could I miss that one ;-)
Great. Thanks alot for the heads up.
-Bo Andersen-
Offline TPS
  •  2,627 2,627
« Reply #3 on: August 11, 2015, 03:04:32 PM »
see attachement
« Reply #4 on: August 11, 2015, 04:36:41 PM »
Very nice sheet ... and well organized.
Thanks for sharing Thomas,
Russ
« Reply #5 on: August 13, 2015, 12:18:55 AM »
Added the DoOEMButton(316) to the script, it works like a charm.
Also thanks for the xls, much better than the "OEM list" I have.
Thanks again.
Best Regards, Bo Andersen.
« Reply #6 on: October 24, 2018, 11:57:37 AM »
@fabhund...  Any chance you could share your toolsetting script???
