Hello Guest it is October 02, 2026, 04:00:42 AM
Author Topic: Saving the selected spindle speed range  (Read 55413 times)
« on: August 09, 2015, 02:24:22 PM »
I added a DRO to the standard screenset that lets me select the Spindle Range, but when I close Mach4 and re-open it, the range goes back to zero.
How can i have Mach4 remember this setting?
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Saving the selected spindle speed range
« Reply #1 on: August 10, 2015, 05:24:34 PM »
have a look at using script to save the value of the dro to your profile, and then load it on startup.
DazTheGas
Offline dude1
  •  1,253 1,253
« Reply #2 on: August 10, 2015, 05:30:21 PM »
write to .ini its in the scripting manual in the manual section of mach web site
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #3 on: August 10, 2015, 05:41:27 PM »
Correct, thats what writing to the profile does ;-) by doing it that way it auto writes in the ini and auto loads it on startup.
DazTheGas
« Reply #4 on: August 13, 2015, 10:08:57 AM »
DazTheGas
I looked thru the .ini file and I don;t see a setting that is in there for the selected spindle range.
How do I know the format that this entry should have?
« Reply #5 on: August 13, 2015, 10:37:32 AM »
You can add any settings to the .ini file that you want, and use any format you want.
« Reply #6 on: August 13, 2015, 10:55:30 AM »
OK, what is the format to write this stuff to the ini? Is this documented somewhere?
And this means there is no "standard" .ini setting for spindle range, right? So I will have to use a script to take care of saving and restoring.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #7 on: August 13, 2015, 11:55:48 AM »
give me a little more explanation on the dro.
what sets its value or what value it sets etc and i will write one for you as an example to you on track.
DazTheGas
« Reply #8 on: August 13, 2015, 01:03:46 PM »
The DRO is set to DRO Code "Spindle Range"
thanks,
Offline dude1
  •  1,253 1,253
« Reply #9 on: August 13, 2015, 05:01:08 PM »
have a look at this
