Hello Guest it is October 24, 2026, 10:56:32 PM
Author Topic: Dual Channel Output TP  (Read 10011 times)
« on: August 05, 2015, 04:08:48 PM »
Brian,
Are there any plans or current implementations of dual channel cnc control in M4. I have an application that requires 2 heads. Means I have 2 x's, 2 y's.... I would need to be able sync the 2 channels via MCODE or other function. Basically a 2 spindle machine for high production. I am considering Fanuc for this but if you see a way to do it in Mach, I am all in.
TP,
What do you think? Having it done with 2 FPGA's is easy but then you have 2 Mach's running. One Mach, 2 FPGA's??? Possible.
Re: Dual Channel Output TP
« Reply #1 on: August 05, 2015, 08:11:08 PM »
Need more data ? Gotta sketch ???
« Reply #2 on: August 06, 2015, 05:40:34 AM »
Like a lathe with 2 turrets and live tools on both. And a sub. Also known as a MillTurn. Mori Seiki NT series is a good example.
Or imagine a router with 2 independent Gantry and independent atc units.
« Reply #3 on: August 06, 2015, 12:19:38 PM »
OK it is going to depend on HOW you define interact between the 2 sets . It would be simple IF each set ran as a seperate unit just use a controller that allowed a download to ram for each of the FPGA's Heck you could have 6 if you wanted. Then a timed signal to start.  The tool changes would be controlled from a PLC (hard or soft)for each unit.  They would NOT have to run the same program for each unit it could be a progressive line where each stage is a a continuing process to a part .
IF you mean being able to control up to 6 or more control sets in sets of 3-4 BUT not all 3 sets of 3 axis at teh same time YES compilcated but yes it is possible from a single Mach3 . BUT I certainly would not want to have to write the Gcode for that beast. Well actually that would be a Cool one to do. Just would not want to do it every day.
NOW if you mean 2 totally interactive units that ran coordinated actions as a unit NOPE that takes a LOT of HP CPU wise( mulitple cpu's running parrallel)
