Hello Guest it is October 25, 2026, 01:56:28 AM
Author Topic: MPG/Homing problem  (Read 7867 times)
MPG/Homing problem
« on: August 05, 2015, 08:15:58 AM »
Any ideas on this one guys?
I am using Mach3 (.062 ver) with the "d" SmoothStepper plug in and get some odd problems.
1. Using the Mach3 fly out MPG, when I hit "-Z" the spindle moves up, but when I press again it moves down. If I press it repeatedly I do not know if it is going to move the spindle up or down. If I press "+Z" I get the same random behaviour.
2. Z axis will jog (but as above behaviour). BUT if I try to home Z I get motor noise/vibration/juddering but screw does not move.
If I change pin outs in Mach3 and use Y's pin out for Z, when I ref home spindle bounces off BOTH hi and low switches....it will do this forever until I hit reset. Position value soars to thousands. Axis does not seem to know where it is. Limit switches WORK (if I jog spindle I can arrest movement by manually hitting the switch).
This afternoon I am going to move the Z motor wires to the Y smoothstepper and see what happens. I have reinstalled Mach amd the plug in...no change. I am running win8
