Hello Guest it is November 22, 2026, 08:09:45 AM
Author Topic: lpt port mode  (Read 11670 times)
lpt port mode
« on: May 01, 2007, 08:19:09 AM »
Hey there all!
Working on setting up a "new" machine for Mach3 usage...  was just going through the bios... and i have the option of setting the LPT port mode...  factory default is IBM PS/2...  is currently set to "ECP" or Extended Capability Port protocol....
any thoughts/ reccomendations on this?  I am thinking i will do the PS/2 compatibility mode, as i imagine it stands less chance of screwing with Mach's control over the parallel port.
Thanks in advance for any input!
-Nate
Re: lpt port mode
« Reply #1 on: May 01, 2007, 11:10:06 AM »
I usually set mine to ECP+ EPP and dont have probs.
Re: lpt port mode
« Reply #2 on: May 01, 2007, 11:44:22 AM »
ah, ok... i shall try that out then...  just wasn't sure if those modes might cause... well.. issues.  After i get the machine re-loaded w/software & such, i'll see how it does.
Thank you for the input!
