Hello Guest it is November 13, 2026, 06:07:41 AM
Author Topic: Single Switch, Homing + Limits  (Read 13925 times)
Offline royce
  •  40 40
« on: July 31, 2015, 11:24:45 PM »
I've been scouring the forums for the past couple months now and have spent the last two months completely retrofitting new controls for a Bridgeport Boss 5 Series 1 CNC. I'm using a PMDX-126 BOB & ESS, along with the original steppers and Leadshine DM2282 drivers. The first thing I did before my controls were built was wiring the limit switches to NC. With these Bridgeports, as far as the X+Y axis go, its only one limit switch. I've assigned them in mach, and have the limits working properly. However i'm having troubles setting up the homing. I.E., in M4 X axis has --, ++ & Home as the same input. When I try to home my axis it will of course hit the limit switch. I am unable to limit override and jog off because Mach sees + & - hit (my theory). This freezes movement on X,Y & Z axis. I have to manually disable the + axis to jog off the switches, restarting Mach4 several times. Also it seems that if I close Mach when a limit switch has been hit, it won't show it under diagnostics on next start up. It will only show that the limit switch has been hit if I go into the Mach setup screen, and exit out. What am I missing here?
Bridgeport Series 1 Rigid Ram Retrofitted w/PMDX126 BOB, PMDX107, Hitachi WJ200 VFD,ESS, Leadshine DM2282 Drivers running Mach4 comfortably.
Offline dude1
  •  1,253 1,253
Re: Single Switch, Homing + Limits
« Reply #1 on: July 31, 2015, 11:39:57 PM »
ask on the ESS forum Andy has a way around it or Steve Stallings may know a way around it, it`s a problem that has come up before
Offline royce
  •  40 40
« Reply #2 on: July 31, 2015, 11:47:47 PM »
I'll be at Steve's CNC meeting this week @ PMDX's HQ and bring the topic up. I'll report back on my findings unless anyone has any more information. BTW, seems there's not a register link on Warp9's site for me to access the forums unless my login information was setup when I purchased the ESS.
**Edit**
After googling "warp9 forums register" it brought me to the page on the third listing.
« Last Edit: July 31, 2015, 11:53:04 PM by royce »
« Reply #3 on: August 02, 2015, 12:35:38 AM »
Homing is handled almost entirely in the plug-in.  All Mach4 does is tell the plug-in when to start homing each axis.  It then waits for the plug-in to tell Mach4 that homing is done.  It is up to the plug-in to ignore limit switches when necessary (as it is in this case).  So *if* the homing sequence is aborting when it hits the home/limit switch, that is an issue with the ESS plug-in.
As far as being able to jog off of limit switches, the current Mach4 build (2580) appears to have a properly functioning "Limits Override" button in the default screen set (wxMach.set).  In some previous Mach4 builds (I don't remember which ones off hand but I think it was many builds ago), the "Limits Override" button did nothing.  Jogging off of limits switches is partly handled by Mach4 and partly handled by the plug-in, in that the plug-in needs to be aware of limits override being active and ignoring the limit switch function (our plug-in disabled Mach4 on limit switch trigger except when override is active).  If you see a message in the Mach4 error/status line saying something like "can't job towards X--", then Mach4 doesn't think override is active.  If the machine just won't move, or something else happens, then it may be the ESS plug-in.
Bob
PMDX
Offline dude1
  •  1,253 1,253
« Reply #4 on: August 02, 2015, 01:06:57 AM »
if as bob say`s its the ESS ask look on the ESS forum there is a way around it, I don't know how well it works if, if the work around is still valid
