Hello Guest it is November 14, 2026, 02:43:45 AM
Author Topic: gcode issue  (Read 10234 times)
gcode issue
« on: July 31, 2015, 02:30:40 PM »
Whomever,
I have a problem when I run this gcode program it will only go to line 483 and stop there instead of going to the end. Even if I try to look at it in the window its open again it only goes to line 483 and stops but if I hit the edit gcode button I can see the g code all the way to the end of the line which is 761. Not sure if this is a Mach 3 issue or bobcad issue. Thanks
Joe
Re: gcode issue
« Reply #1 on: July 31, 2015, 02:39:48 PM »
You need a Mach3 license to run all of the code.
Re: gcode issue
« Reply #2 on: July 31, 2015, 03:31:22 PM »
Thanks...I have a license I guess I did not install it correctly?
Joe
Re: gcode issue
« Reply #3 on: July 31, 2015, 03:41:07 PM »
You were right Thanks lol sorry pretty nooobish of me...Reinstalled all is well.
Joe
