Hello Guest it is October 24, 2026, 07:12:44 PM
Author Topic: Mach 4 DRM  (Read 7507 times)
Mach 4 DRM
« on: July 28, 2015, 08:36:21 AM »
Can I contact Newfangledsolutins and reset my PCID if I upgrade my computer.
I hate DRMs like this.
Can I run Mach3 as a backup if I also install 4?
« Last Edit: July 28, 2015, 08:38:07 AM by tahustvedt »
Re: Mach 4 DRM
« Reply #1 on: July 28, 2015, 10:24:25 AM »
When you change computers and have a new PCID, you will need a new license key.
The process is to install Mach4 on the new computer and use Help > About to read your new PCID. Then use the MachSupport.com web site to generate a new license key and have it emailed to you automatically, or contact your reseller to obtain a new license key. You may have up to 5 license keys at once, so hobby users with multiple machines typically do not need to purchase multiple licenses.
You can have Mach3 and Mach4 installed on the same computer at the same time if you are using an external pulse engine. Installing Mach3 and the Darwin software pulse generator for Mach4 at the same time is not recommended.
Steve Stallings
www.PMDX.com
« Last Edit: July 28, 2015, 10:27:01 AM by Steve Stallings »
Steve Stallings
www.PMDX.com
