Hello Guest it is October 24, 2026, 09:10:42 PM
Author Topic: elapsed time?  (Read 14085 times)
elapsed time?
« on: July 27, 2015, 07:03:55 PM »
Has anyone figured out a way to display toolpath elapsed time in Mach 4 (time from cycle start to toolpath finish)? Mach 3 has this feature and I'm suprised Mach 4 doesn't include it.
Hit the e-stop! Hit the e-stop!
Offline dude1
  •  1,253 1,253
Re: elapsed time?
« Reply #1 on: July 27, 2015, 07:05:20 PM »
in the probing screen set it`s there and it in the forum as well
Re: elapsed time?
« Reply #2 on: July 27, 2015, 08:55:21 PM »
Hi blockhead, thanks for the response. Where is the probing screenset located? I see screenset for M3 on the website but none for M4. I ran several searches on the forum and did not find info on elapsed timers... could you point me to the post?
Thanks in advance.
Offline dude1
  •  1,253 1,253
Re: elapsed time?
« Reply #3 on: July 27, 2015, 09:04:59 PM »
Re: elapsed time?
« Reply #4 on: July 29, 2015, 06:50:17 PM »
I installed to the Mach3Mill profile, I don't see any "Probing" tab, or any "Elapsed Time" tool.  What's supposed to happen?
Offline dude1
  •  1,253 1,253
Re: elapsed time?
« Reply #5 on: July 29, 2015, 07:17:41 PM »
its in the wxMach_Hobby.set under view load screens
Re: elapsed time?
« Reply #6 on: July 30, 2015, 12:40:29 AM »
OK it loaded, but all it's doing it "elapsed time since booted", not even runtime.
I was hoping for a view to see the projected runtime, that's what I actually need out of this.  Mach3 had that "Simulate Program Run" button in Toolpath.  That's what I need.
Offline dude1
  •  1,253 1,253
Re: elapsed time?
« Reply #7 on: July 30, 2015, 12:49:52 AM »
that`s more than I get I cant even get it to work
I don't know if that has been done yet you may have to script it your self
Re: elapsed time?
« Reply #8 on: July 30, 2015, 08:10:41 AM »
Load some code then press cycle start it should reset and start running again  Sometime it does and sometime it does not. It wil normally run and stop ok just not reset correctly.
