Hello Guest it is November 23, 2026, 09:15:54 PM
Author Topic: Newbie help setup for CNC 6040Z USB2.0 port  (Read 15524 times)
« on: July 25, 2015, 04:48:29 AM »
Hi All,
I have a new 6040Z machine I purchased off Aliexpress. It is a newer machine, that has the usb port only.
I have purchased Mach3 and have used some of the script ('porbe') and a plugin called NcUsbPod.dll that the Chinese supplier sent me.
I am following the tutorials as best as I can, though much of the parallel port info is not applicable to me.
I am up to Homing, Limits and Offsets. I have wired in limit switches, and now I am trying to set the machine coordinates. When I hit 'reference all home', my Z axis moves downwards (in the negative direction). From the tutorial, it seems it should home upwards.
Also when I manually trigger the limit switch, it all shuts down, rather than visit the next home switch.
http://imgur.com/iVKowmm < item on Aliexpress
http://imgur.com/HUk6UGG < assembled
Thanks for checking out my problem!
Re: Newbie help setup for CNC 6040Z USB2.0 port
« Reply #1 on: July 27, 2015, 01:25:04 AM »
Still having trouble setting up my reference all home functions.. I recorded a video to show my problem. If you think you might be able to help, please have a look >> https://youtu.be/gq942IFDMKw
Notice that the Z axis and the direction of movement after I hit REF ALL HOME..
When I open button script > Reference All Home I get the following script..
http://imgur.com/MVxsaxC
  •  9,378 9,378
« Reply #2 on: July 27, 2015, 02:26:49 AM »
Just a thought but it may help if you make your video public so that others may view it.
« Reply #3 on: July 27, 2015, 02:30:15 AM »
Sorry, all sorted now!
  •  9,378 9,378
« Reply #4 on: July 27, 2015, 02:38:02 AM »
I am pleased you have resolved the problem.
« Reply #5 on: July 27, 2015, 02:51:35 AM »
I sorted the public video settings, it should be open to view..
The Z axis is still going in the wrong direction when referencing though.
« Reply #6 on: January 04, 2017, 02:16:55 PM »
hi, I have the same machine I think. have you resolved teh problem and could you show some pictures of the breakout board connections and switch wiring etc. have you had any other problems?
