Hello Guest it is October 25, 2026, 12:34:21 AM
Author Topic: Save/restore machine position  (Read 8835 times)
« on: July 24, 2015, 10:47:48 PM »
Is there any way to save the machine's position when shutting down Mach3 and restore the values on startup? It doesn't appear that there are a macros reserved to run at startup or shutdown, which would allow development of a macro for this purpose. I realize that for stepper-motor based machines this might not be the most accurate way to go if the machines moves a couple of steps when powered up (as far as I can tell, mine doesn't suffer this malady). Even if not fully accurate, it would allow writing a macro that moves the machine very close to home, the ref all axes.
Re: Save/restore machine position
« Reply #1 on: July 24, 2015, 11:03:16 PM »
Simply tell it to SAVE the fixtures on close. I t will open back exactly where you left the DROs reading when you closed.
« Reply #2 on: July 24, 2015, 11:09:12 PM »
 I believe saving fixtures saves the *offsets*, not the machine position.
Any time I launch Mach3, the DROs start in the same place, no matter where the machine was left. It doesn't even ask me if I want to save fixtures unless I've changed one or more of the offset values.
